pretty good ryan
i opted to keep all the tolerances to the tighter side of the specs
,will give you probably unnoticeable performance gains
,as in taking a
.37 gap down to
.28 as per the tighter side of the spec will give another
almost 0.1mm of valve opening
plus looser specs mean noiser tappets especially on
higer lift cams where you hear it more
i very luckily got all of mine within 0.02 of the lower end of the spec
,i swapped most shims around and only had to buy 4 new ones
