Just got my baby back from local bodyshop with two new rear arches.
Battery was flat after two weeks witha door open, so they started it with a booster jobby, and did something to the stereo, as it wouldn't work.
I took the stereo out and checked the fuse on the back, fine.
Noticed there are two places you can put it on the head unit to I tried the second position, works now.
However it forgets all the presets when you turn it off, it is only running from the ignition live.
I guess this set up is for cars with the ignition live and battery live reversed, so there must be a problem with my permanent live.
Where is the fuse for this live? Anyone got any other suggestions for the problem?
Cheers!
