Just like to say great help so far with all the minimal problems i have had but i need a favour.
To cut a long story short, on boost my car sometimes does not boost or drive, i.e will not go past 3k, feels stuttery, this has only happened twice and each time it fixed itself.
Anyways recently the car has been running on lower boost, i.e the turbo feels weaker, this returns also to full boost the next day or next hour!, also on quarter throttle the car jerks a little, cuts in and out of boost, half/full throttle is fine.
Im pretty sure the 2 above problems are related, anyways have changed the plugs to a colder grade, checked the dizzy and rotor arm also and they are fine as well as the leads.
I really need some suggestions as this is all i need to do to make my 2 perfect.
Any ideas, suggestions, am thinking of changing my bleed valve to a G valve and maybe replacing the AFM or am i going down the wrong track?
Ross
