This is getting on my last nerve!!!!
I have a buddy club spec 2 with a slip fit middle joint that will not seal properly!!
I have used fire gum in and around the joint but the sheer heat from the buddy club just turns it to crumbs!!
I have it heat wrapped and held on with jubilee clips, but as the air escaping is such a wide area it just slowly moves the heat wrap apart and starts blowing again!!!!
I wouldn't care that much but it is blowing enough to make me drop from 0.7bar at 5000rpm to 0.55!!!!
It is poor design as when you put the system together the pipes are a snug fit but as soon as you mount it on the car and tighten the other bolts it puts strain on the pipework causing the gap and therefor a blowing joint
Any ideas???
Alex
