fitting fse power boost valve
sharpy01
Post by sharpy01 »
Hi all,
Im struggling to fit this, can someone point me in the right direction as to what connects to where? :roll:
I have the fuel filter off allready
User avatar
Lauren
Re: fitting fse power boost valve
Post by Lauren »
Question i have for you, is why are you fitting one?
tom_snelling
Post by tom_snelling »
Pretty pointless unless you have some sort of remap on a forced induction imo. Will just cause you to overfuel and/or use loads of fuel.
The fuel pressure for your car as standard is what it needs to be. Raising that is a bit silly.
anthonyg
Post by anthonyg »
I found that the fse adustable fuel pressure regulator worked nicely with an after market filter and exhaust.
User avatar
Lauren
Post by Lauren »
anthonyg wrote:I found that the fse adustable fuel pressure regulator worked nicely with an after market filter and exhaust.
Well i guess as long as you set it up well on the rollers it can't do no harm.
I had one of these on my sc conversion, but i needed it because the NA fuel pump was running lean under acceleration otherwise. Made another 15bhp with it.
anthonyg
Post by anthonyg »
Yeah my Sc loves the fse too! It made 145bhp @the wheels on stock boost of 8.03psi with a k&n and sports exhaust :thumleft:
sharpy01
Post by sharpy01 »
ye i have just fiited a k&n filter and moongoose zaust so hopefully it should make a difference. I also have the pressure gauge to set it up, but not sure how to do that either. What pressures should it read?
anthonyg
Post by anthonyg »
Its best set up on a rolling road it can make a big difference
User avatar
Lauren
Post by Lauren »
anthonyg wrote:Its best set up on a rolling road it can make a big difference
Its the only way to do it properly really.
