[Mk2] [Turbo] Installing Defi boost + water temp
LuizeGT
Post by LuizeGT »
got these coming from japan.
the water temp one scoming with an adaptor that fits into water piping sothat part isnt hard but how do i wire up the boost sensor one? im used to mechanical gauges not eleccy ones[/code]
SW20Paul
Re: [Mk2] [Turbo] Installing Defi boost + water temp
Post by SW20Paul »
I think they come with a sensor that plumb's in like a normal gauge i.e intake manifold.
Then the gauge is then pluged into the sensor.
Never seen em or fitted one but thats how I guess it would work :mrgreen:
tanker3000
Post by tanker3000 »
Its really easy, i have just installed mine, its just a wire from the control unit to a little black box (sender) that you mount as close to the source as possible then from that to the inlet with a tee piece and some vac hose.
If they are brand new they come with indestructions any way.
Chris
LuizeGT
Post by LuizeGT »
cool. just worried incase it came with Jap instructions lol. so its basically the same as a mechanical one in terms of plumb into Vac line but then this plumbs into a sensor instead of straight to the gauge.
ace \:D/
splashnatz
Post by splashnatz »
which defi gauges are they Lu, do they need the defi-link in order to work, or do they work standalone ?
LuizeGT
Post by LuizeGT »
they come with the link control unit. its these ones.
