[Mk2] [Turbo] whats the stud pattern for exhaust manifold on rev3 1995 turbo gt
Mad-Mark-UK
Post by Mad-Mark-UK »
Hi All
Can anyone tell me the correct stud pattern for exhaust manifold on an MR2 Tubby 1995 GT, is it 7,8 or 9 studs im looking at replacing the gasket as mine has started blowing but might just replace the whole manifold and gasket at the same time.
Many Thanks
Mad-Mark-uk \:D/
Ian Geary
Re: [Mk2] [Turbo] whats the stud pattern for exhaust manifold on rev3 1995 turbo gt
Post by Ian Geary »
it's 8.
at least it was on my 94 rev3.
Do you think the manifold really needs changing? they're pretty solid things, unless you want an aftermarket one I suppose.
hth
Ian
Mad-Mark-UK
exhaust manifold stud pattern
Hi Ian
Thanks for replying I thought it was 8 but needed someone else to clarify??? .
I cant find any 8 stud pattern manifolds anywhere for love nor money,I have an aftermarket s/s one on my tubby at the moment but I herd they are prone to cracking, the cast one is able to handle up to about 400bhp.
If my manifold has cracked or warped causing the gasket to leak I will need to replace it but to start with I just need to replace the gaskets exhaust and turbo and hopefully stop the ticking noise as its driving me mad now.
Many Thanks
Mad-Mark-uk \:D/
JeffD
Post by JeffD »
8 - heres a photo (8th item down).
http://www.flashmetal.com/index.asp?fun ... T&catid=70
Earlier cars have a 2 piece gasket (shown above)
