i guess you could use a mild detergent.
(mild) and then thoroughly dry it.
Then apply a thin spray oil like ptfe spray.
.to keep the muck out.
How often do you clean it.
I have heard that for normal UK road use you should get away with cleaning it 3 times per year.
.every 6-8k miles.
The correct fluid cant be that expensive can it?
