my build, when it happens, will consist of.
Custom grind cams
(in the 305deg duration and around 10.5mm lift)
Carrillo forged H-Beam rods
(old style with 40mm big end)
Wiseco, Mahle or Wossner forged pistons, depending on what i decide.
already got a set of Wiseco ones which have been CNC finished for use in an Atlantic engine but fancy a set of Mahle's
(theyre lighter)
Smallport head with extensive port reworking
Custom plenum inlet manifold
(throttle bodies are alright for a quick and easy fix, but to do things properly youve got to keep it single throttle body and plenum!)
VEMS or Emerald standalone engine management
Aero profiled crank
Lightweight flywheel
(3.5kg or thereabouts)
Fully balanced rotational and reciprocating assemblies
(crank, pulleys, flywheel, clutch cover, pistons, rods, etc)
Early clutch setup
(not sure which manufacturer yet though, will run standard friction plate and an uprated pressure plate though.
i want early setup because its lighter with less rotational mass being smaller diameter.
the power handling is more than enough)
should be running about 11:1 compression, 9000-9500rpm, 200bhp and a powerband from around 6500-9000rpm.
im going to de-tune it though so that its got an over-safe working margin to ensure i get a decent rebuild interval out of it.
anything over 5-10k would be satisfactory, over 20k would be an acheivement!!
first build im going to do though as a temporary fix is to run stock bottom end at stock revs, small port head and custom inlet manifold 272 or 288 degree cams, lightweight flywheel, either standalone engine management or a Greddy eManage as a short term fix, just mildly fettled for a solid 160bhp.
should have that sorted by August hopefully, im too busy getting the chassis and suspension sorted at the moment to find the time to spend on the engine stuff.
ive got most of the expensive parts already, just need to find time to use them lol
