What are they like?
Frosty617 wrote:It's just the flapping about I want to stop!
Does anywhere in the UK do them this cheap?
Be warned- I got hit for
£24 import duty on mine
Frosty617 wrote:Well that's certainly a lot cheaper! Just the one bag enough?
Clicky
- This the stuff??
£7.50!!
What do you do just mix the stuff up and pour it in over the old mounts? Or do you take the old rubber out? If so how do you ensure the spindles(??) are in the corrct place?
Limeymk1 wrote:3 bolts on each.![]()
Oh and Welcome to IMOC!(How rude of me not welcoming you earlier
Jim-SR wrote:so long as the rubber mounts arent badly worn id just do the rear mount, this is the one that stops it winding up on acceleration and youll still get some compliance from all the other mounts
jimi wrote:You could always try what I'm experimenting with
I bought a large tube of this
http://www.makingdiyeasier.co.uk/images ... ealant.jpg
in Black for doing my T-bar seals.I had loads left so decided to experiment on a spare front engine mount I had.
Did this
http://www.mr2oc.co.uk/membersfiles/dscf0001a.jpg
and left it for a couple of days to cure, then fitted it to my car.
It certainly stiffened up the mount to the extent that I can feel vibration where there was none before, especially at idle.
It does take all the rock out of the engine when you accelerate hard.
I'm going to go back to a standard mount on the front and repeat the experiment with the rear mount, to see what difference that makes.
Then probably try it with both and also with partial fills untill I get the result I want.
How long the silicone will last remains to be seen, but so far so good
( about a month
I'm trying to get a specific data sheet for the sealant I used find out what the hardness of the sealant is, from browsing the net I've found that depending on manufacturer silicone sealant ranges from about 22 to 60 shore.
The RS compound is around 70 IIRC.
The beauty of using silicone sealant is that you can fill a bit a time until you get the stiffness you want, unlike the poly mix where you have to do it in one go
Jimi
jimi wrote:I got the sealant from Homebase its Unibond Super all purpose Silicone Sealant, Black( waterproof for interior/exterior use
) around
£8 for a big tube, you could fill dozens of mounts with 1 tube if you just fill the spaces.
, very easy to work with.
As I said only time will tell how it stands up to the wear and tear, having said that its that cheap and easy to do it wouldn't be a big deal if I had to do it yearly.
What I'm aiming for is to remove the engine rock on hard acceleration without making it rigid and transmitting the vibrations all over the car.
