[Mk2] [Turbo] Thank you 3s Service centre...
gozza91
Post by gozza91 »
Just wanted to say a big thank you to James and the team down @ the 3s service centre. They just changed my cambelt, aux belts and oil at a fantasticly low price and my car is now running as smooth as when i bought it over 2 years ago! I am so pleased :D Can't recommend them enough!!
Anything you need doing, just ask James:
http://www.3sservicecentre.co.uk/
ormzy
Re: [Mk2] [Turbo] Thank you 3s Service centre...
Post by ormzy »
As a matter of interest, how much they charge you?
Need mine doing to, and was going to tackle it myself, but if there price is right, might opt to keep my hands clean.
3S Service Centre
Post by 3S Service Centre »
prices can be obtained through the pm system.
Leon.
Post by Leon. »
gozza91 wrote:They just changed my cambelt, aux belts and oil at a fantasticly low price and my car is now running as smooth as when i bought it over 2 years ago!
Please don't tell me you've not had the oil changed for 2 years? 8-[
gozza91
Post by gozza91 »
Ha ha, Yes I've had the oil changed, just not with mobile 1. Plus it was all the little ticking noises and squeaking from the belts that were driving me insane!
jeffry-
Post by jeffry- »
Maybe 3s can sort out why my ct20b wont hold 1.1 to redline but it will 1bar , cause its peeing me off and im not getting much help on this forum
#-o
Century Motorsport
Post by Century Motorsport »
jeffry- wrote:Maybe 3s can sort out why my ct20b wont hold 1.1 to redline but it will 1bar , cause its peeing me off and im not getting much help on this forum
#-o
What boost controller are you running? Its probably something to do with the settings in that.
Regards,
Nathan
jeffry-
Post by jeffry- »
Blitz dual selonoid thingy , with 4 channels and gain and ratio.
Currently have it set to 60 ratio and 20 gain and its doing my head in
:mad:
I want to drive 1.1 during the day and then ofcause i'll probably have to turn the blitz down at night cause incase it overboosts(cold temps)
3S Service Centre
Is your car decat ??
jeffry-
Post by jeffry- »
It's got a downpipe , have checked for anything inside fowling the wastegate door and its all good inside.
3S Service Centre
Is the acuator perfectly operational?
jeffry-
Post by jeffry- »
To tell you the truth i've yet to test it , it's as old as the turbo which is a ct20b bought second hand from someone here. Im hopeing to get my hands on a new actuator soon , just hope they dont cost the earth.
Would the actuator cause this then , not holding boost above 1bar ?
3S Service Centre
yes! its 3rd most common cause of overboost/underboost problems.
Last edited by 3S Service Centre on Wed May 09, 2007 3:35 pm, edited 1 time in total.
3S Service Centre
double post
jeffry-
Post by jeffry- »
Thankyou , very helpful :thumleft:
Last questions from me , what type do you recommend and where should i get one from?
Was thinking of a 15psi or should i get a lower one . Maximum holding boost pressure i want to run is 1.2 at a later date. But for safety reason's id prefer to hold at 1.1
3S Service Centre
Give fensport a call.
jeffry-
Post by jeffry- »
Will do :thumleft:
Wonder what most people run on here , regarding uprated actuators hmmm O:)
jeffry-
Post by jeffry- »
Oh i forgot , can you change an actuator with the turbo and downpipe attached to the car?
I don't have to take all the downpipe and turbo off do i :pale:
3S Service Centre
lol the answer to your first question begins with m and ends with h :clap:
It is possible to change the acuator with the cat in place, its just tight and tricky, infact so silly it can be quicker to remove the cat, as its the re-securing of the push rod thats the most important part.
jeffry-
Post by jeffry- »
Ouch that means the manifold will have to be moved out too.. The oil filter holder gets in the way of the downpipe, to get the downpipe off i have to move the manifold out slightly so the oil filter holder doesn't get in the way .
Im worried now :pale:
REV 2
