I had an annoying problem like this on my alternator.
In the engine bay where the fuse box, there should be a thick white lead that is bolted.
with the engine ignition off removed this cable and using a multimeter on the 10A current range attached one cable to the cable you have remove making sure it doesnt touch any metalwork.
attach the other cable of the multimeter to the bolt that you have removed the cable from.
.you will now be able to measure any current that is been drawn which should be minimal if all doors are closed and no accesories are switched on.
.mine was drawing in excess of 1amp indicating a faulty regulator pack or staor windings in the alternator.
.something to check even if the alernator has been reconditioned.
