A chip won't change the rev 1 speedo at all, they only work on rev 2 to 5 cars.
It may remove the limit but if you have power steering and the chip isn't a clamping type then the PAS will stay on at motorway speeds.
For a rev 1 you need either a UK speedo and a clamping delimiter, or a converter gearbox that goes into the speedo cable
(also messes with PAS).
