[Mk2] [Turbo] Timing belt question
MR2_Babe
Post by MR2_Babe »
What other parts are needed other than the timing belt for a timing belt change? And is there anything else worth changing when I'm at it? Thanks.
blueorb
Re: [Mk2] [Turbo] Timing belt question
Post by blueorb »
Cambelt tensioner
Idler pulley
Air con, P.S, alternator belt
And make sure who ever does the job has done one before, or it could turn into a nightmere job!
They are trying to build a prison!
ormzy
Post by ormzy »
Also, when the belt is off, check the water pump gear for noise and free play, but if money isn't an issue, replace anyway, as if it goes and leaks in the future, youre gonna have to do the lot again. water pump is about 90 ish quid.
Driftlimits Performance
IMOC Affiliated Company
Timing belt
Alternator belt
Air con blet
idlear bearing x 2 (one is used on the tensioner bearing)
Tensioner
and yes check the condition of water+oil pump.
:D
