87 T-Bar
, 142,800 miles, FSH
(partly Toyota, partly independent).
This is a solid example with lots of history, new parts and thousands spent on it with receipts to confirm.
New clutch slave cylinder, gearbox and clutch replaced several years ago, radiator, exhaust, handbrake cables and many other bits.
Had a signifcant welding job done
(including new sills and underside protection) a short while ago.
Drives well, the engine pulls surprisingly strong
(except it may not be as smooth as new), gearchange is light and smooth.
Very good leather interior.
Bodywork
- solid due to the work done, however 1 rear and 1 front arch has some rust
(not as bad as on many), also some rust under the rear bumper, and
the paint is peeled in two small areas on the sides
- so some cosmetic issues.
Have pics to email
(or look at pistonhead.com classifieds).
2 Good tyres, the other 2 will need replacing.
I can also add 4 nearly new Toyo Proxes on very good teardrops for
£75.
The car will have a full yr MOT
(incl new rear caliper) from Sat, can be driven and enjoyed without any further work, but could be a good basis to make it excellent.
Asking
£690 ono, Selling due to another MR2.
Im based in Ealing, West London.
Contact: 07862 722 851 or
[email protected]
