It's K reg MR2 GT2.0 T Bar.
It has done 135,000 miles
List of things I know are wrong with it:
One of the wing mirrors was connected up incorrectly so when you use the electric adjuster up-down is left-right and vice-versa.
Leaking valve stem oil seals
Some of the plastic armour sheets on underside are missing
One of the front headlights is stuck in the up position.
Dint over rear wheel arch
Bit of mottled paint on front wing
Front panel
Rust bubbles noticable on roof at top corner of windscreen
Driver's seat is a bit knackered
Boot liner is in a bit of a mess and has come away at back from the car body.
Thing that holds the engine compartment lid up when open has a clip to keep it tidied away when closed.
Interior in general need of cleaning.
It's still got the original alloys so they're somewhat tarnished these days.
And last but not least
It's been sat in the car park at work since October and needs a tune up
The switches the tell if the doors are open are worn and sometimes need flicking to make them work again
Images should be availale here
