Hi New Member
midenginedmaniac
Hi New Member
Post by midenginedmaniac »
Just moved over from MR2OC
A few pics of my MK1
Mikejc
Re: Hi New Member
Post by Mikejc »
Welcome to IMOC :D
You state that you've, "just moved over from MR2OC" You given up on things over there lol ;)
MikeJC
midenginedmaniac
Re: Hi New Member
Things are a bit serious. Just been banned for a week for commenting on the daily stare. [-X Thought I would Try it over here. Time for a new sticker maybe. :-$
Quigonjay
Re: Hi New Member
Post by Quigonjay »
wise man
welcome to imoc 8)
that is a stunning example of a mk1 :thumleft:
midenginedmaniac
Re: Hi New Member
Thanks. I have done lots of mods. The LED tail Lights and Leather Retrim being my latest. Hope the mods are not as sensitive on here.
Re: Hi New Member
Welcome mate, beautiful example of a MK1, I like :thumleft:
Quigonjay
Re: Hi New Member
Post by Quigonjay »
midenginedmaniac wrote:Thanks. I have done lots of mods. The LED tail Lights and Leather Retrim being my latest. Hope the mods are not as sensitive on here.
some of your mods would probably be frowned upon by some of the die hard mk1 fanatics but as long as you stay out of the mk1 section you should be ok 8-[ :lol:
not sure i'm understanding your reason for getting banned on the OC though? did you actually say something offensive or just something that one of the almighty didnt like?
Cj82
Re: Hi New Member
Post by Cj82 »
Stunning Mk1 mate good work
Welcome
midenginedmaniac
Re: Hi New Member
I wont say the word on here but if you have seen full metal jacket its the G word used to discribe the Oriental Folk. Did not realise it was such a bad word. :shock: I am so sorry. :evil:
dannyroids
Re: Hi New Member
Post by dannyroids »
Very nice Mk1 :) , one of the nicest i have seen.
Welcome to IMOC!
EarL
Re: Hi New Member
Post by EarL »
Lovely Mk1 mate. Keep up the good work, and welcome to the best MR2 club on the face of the earth. :wink:
IMOC. :thumleft:
EarL.
tonigmr2
Re: Hi New Member
Post by tonigmr2 »
That's one of the nicest MK1s I've seen in a while! :shock:
Have fun on IMOC.
T
nakamura
Re: Hi New Member
Post by nakamura »
Fantastic mk1. :thumleft: Welcome to the OC.....sorry IMOC! #-o
Martin.
mikee66
Re: Hi New Member
Post by mikee66 »
what trd mods does it have?
midenginedmaniac
Re: Hi New Member
The worst type. Stickers only. :oops: I have no Idea if anything was modded in the 20 years of ownership but I have put nothing on.
mikee66
Re: Hi New Member
Post by mikee66 »
why the stickers then?
midenginedmaniac
Re: Hi New Member
When I got the car it had a model red car screwed to the dash. I needed a sticker and it was the one that took my fancy in the shop. :lol: I had no Idea who TRD were. Jimi Made me the bracket and put the sticker on it for me. Maybe I should get some TRD bits for the car to go with the stickers. :mrgreen:
mikee66
Re: Hi New Member
Post by mikee66 »
i wasn't aware of any trd parts for the mk1?
midenginedmaniac
Re: Hi New Member
Here is the list. Plenty to choose from. I may have something already and I never knew. :thumleft:
Phase One: STREET PERFORMANCE
Results: Slight decrease in ride quality, improved handling,
improved braking 10-15 hp increase.
TRD Springs
TRD Adjustable Sway bars
TRD Low pressure gas strut inserts
TRD Brake pads
TRD Brake line kit (drain and install ford type fluid)
TRD Header and Exhaust System
High Flow Air filter
Recalibrate fuel injection system (See Engine Preparation Section)
Reset alignment:
Camber Front: -1 degree
Camber Rear : -1 "
Caster : +6 "
Toe in Front: 1/16 in.
Toe in rear : 1/8 in.
Phase Two: AUTO CROSS, STREET PERFORMANCE AND ROAD RACE
(Dependent upon class restrictions)
RESULTS: Decrease in ride quality (lowers ride height 1.5-2 in.),
dramatically improved handling, improved braking.
Instead of phase one equipment:
TRD High pressure gas struts
TRD Springs
Reset Alignment:
Camber Front: -2 degrees
Camber Rear : -1 1/2 degrees
Caster : +6 degrees
Toe in front: 1/16 in. ( 1/8 in. out for auto cross)
Toe in rear : 1/8 in. ( 1/16 in. out for auto cross)
All phase one Modifications, Plus:
TRD Urethane Bushings
" Front and Rear strut tower braces
" Negative camber blocks
" Front and Rear adjustable camber kits
" Engine Modifications ( see Engine Modifications section)
" Light weight fly wheel
" Heavy Duty Clutch
" LSD
" Performance Ratio Ring and pinion Set
" Close ratio transmission gear set
Section 3.3 (Summary)
Engine Components: 4AG
"The bottom end of the 4AG has proven extremely reliable in all
types of performance applications, and the stock connecting rods and
crankshaft will withstand up to 170 hp and 8000 rpm. For applications where
higher hp or rpm are desired, Carillo rods, our TRD billet crankshaft and
dry sump lubrication is required."
"The original fuel injection system is capable of delivering
sufficient fuel to support 140hp with only minor adjustments (see engine
preparation section). Engines that develop over 170 hp will require larger
injector nozzles."
4AG Engine Recommendations
Phase One: Street Performance
Results: Although there are no internal engine modifications, this
phase is no emissions legal. Modifications cause no reduction in low speed
drivability and there is a 15-20% hp increase over a usable power range
from 3000-6500 rpm.
TRD Exhaust header and high flow exhaust
Recalibration of fuel injection system (see engine preparation section)
TRD Spark plug wire Set
TRD Adjustable camshaft gears
Phase Two: Street Performance, Rally, Road Race
Results: With no internal modifications or decrease in drivability,
there is a increase of 25-30% hp increase over a usable power range of
3000-8000 rpm.
TRD Camshafts (272 duration intake 272 duration exhaust 7.5mm lift)
Phases 3-5 require internal modifications
4AGZ vs. 4AGE internal differences.
Strengthened block
Dished forged pistons
Connecting rod journal diameter increased from 40mm - 42mm
Piston pin diameter increased from 18mm - 20mm
This Catalogue also has listings for:
Carbs
Fuel injection modification kits (the second kit includes a potentiometer
and wiring required to adjust the injector pulse.) ,
12 different cams with lift from 7.5mm - 10.7mm
Short blocks with 12.7:1 compression ratios
Oil pump gear set (high volume for stock pump)
Oil pan baffles(for stock pan)
2 flywheels
As well as the aforementioned suspension pieces.
ducatichick
Re: Hi New Member
Post by ducatichick »
fasntastic looking MK1...keep up the good work :thumleft:
