Hey guys,
i have a rev 3 turbo,
mods: exhaust
(Dep2), apexi air intake,.
the car ran 265 bhp
@fly,.
which was good,.
but my dyno centre advised me to get a fuel regulator, as there was a little glitch on the dyno result, and apparently the car was running lean at first, then rich,.
but other then that
, it was ok, held the boost nicely at 14 psi,.
so,.
off i went and got a SARD fuel regulator, had it fitted,.
( the same dyno centre's mechanic done it all wrong, hoses wrong way around,
, wrong clips used, so i was losing fuel, dripping everywhere, pressure wasnt even adjusted
factory setting at 55 psi,.
i did tell him to do it at 40 psi and 1:1 AF ration,.
he obviously ignored that,.
so nevertheless, i got it plugged in properly, fuel pressure set to 45 psi,.
as he claimed that d be better then stock,.
so done it but now my car is doing about 8 mpg OFF the boost
@ about 2k revs cruising!!!!,.
on boost
( which vary.
15-nearly 18 psi
) even half of that,.
i could easily go through the full tank in couple of hours
apparently the place hasnt got a clue, what to do with that car,.
took it back to have it sorted out, they done 20 dyno runs,.
poor car, car only done 1 bhp better than without the regulaotr,
, 266 bhp.
at 17.5 psi!!!.
now that s just completely wrong there should ve been much better result at such boost,.
plus all this overfuelling???.
.and power went down 20 bhp due to heat soak,.
and we got absolutely nowhere,.
error codes are not showing anything,
everything is fine there,.
now obviously i will take the car somewhere else,.
but im thinking,.
has anybody had similar probs after fitting fuel regulator???
Am i missing something here?.
i expected a bit less mpg
, but not this much,.
i will try to plug in the stock FR
( its still there, apparently when you fit a new one, it takes over the stock one, so it wasnt removed
.or should i removed it completely??).
.see if that makes the difference,.
i dont think there is anything wrong with the Sard FR,.
please help,.
any help will be much appreciated, and im sorry about a really long post
cheers guys,
B.
