MBC - fitting problems.
Whizza
Post by Whizza »
Help guys.... I bought an MBC and an adjustable FCD.
I decided to fit the MBC first. So I found the Turbo to actuator hose and after some struggling managed to get it off. I measured the diameter of the hose and bought some longer length from Halfords. I inserted the MBC between the turbo and actuator and set it to it's lowest (counter clockwise screw).
Using my existing after market boost gauge (usually reads about 9psi on full boost - so should be accurate) I floor it and the boost hits 15 psi - and was still climbing :shock: . So I back off the throttle and drive home.
Can anyone explain why a.) I didnt hit fuel cut and b.) why the boost kept climbing.... I have double checked the connections and they look fine - no leaks.....
I then connected a foot pump to the hoses and checked for any leaks with the MBC in the closed postion and it seemed to be fine
Can anyone offer any advice please?
psmiff
Re: MBC - fitting problems.
Post by psmiff »
Have you dismantled the MBC to make sure it is not stuck. Apparently this can happen. What sort of MBC is it. Did you disable the TVSV? What revision is your car.
steve b
Post by steve b »
sure you have the controller the right way round... i'm assuming its a grainger valve? You may need to cut a wind off the spring.
'97 mk1 Mazda Eunos Turbo track car with 260bhp/ton - soon more as Chris Wilsons going to build me an engine over the winter :o) .
Whizza
Post by Whizza »
thanks for the replies.
It is a Rev 1
I have not done anything with the vsv.
The ball is not stuck and when checked with a footpump - it seems to be fine.
The MBC has a small hole on the top if that helps
psmiff
Post by psmiff »
You need to disable the VSV. Cut pipe and plug each end.
Your controller sounds like a bleed valve type, but that should not contribute to the high boost, I would have thought just the opposite but I have no experience of them.
You should have hit cut unless there is already a fuel cut defencer fitted.
Whizza
Post by Whizza »
Thanks guys. It's definately a grainger valve... and fuel cut happened the morning before I installed the MBC..... so It's definately something I have done :-(
To check the actuator - I have used a footpump and i can hear it click - so I'm guessing it's working???
psmiff
Post by psmiff »
How about taking out the MBC, if thats all you have installed, and trying the car without it again. See what happens.
Wondering what you did to get to fuel cut before you fitted the Grainger valve!
raptor95GTS
Post by raptor95GTS »
psmiff wrote:You need to disable the VSV. Cut pipe and plug each end.
you don't need to disable the VSV on a rev 1/2 but rev3+ you do
psmiff
Post by psmiff »
Mines disabled and everything is working fine! In fact, Grainger valve and FCD fitted by Rogue last week who disabled VSV as part of process.
Cliff
Not disable TVSV
Post by Cliff »
Are you sure? What's the difference as i have disabled mine and I have a revision 1?
zero
Post by zero »
When i first fitted my MBC to my rev 1,
I didn't bother to disconect the VSV and got problems contolling the boost.
After disconecting it i had no problems :D also i cut 1 turn off the spring like steve b suggested.
Zero
Steve Horrocks
Post by Steve Horrocks »
also found that i had to cut a coil off the spring in the grainger mbc if that helps at all, couldn't get below around 17psi otherwise.
Gone, but never forgotten
Now with a mk1.5 & a NHB EP3
Whizza
Post by Whizza »
Ahhhh - you guys are so helpful .... I'm welling up here!
Thanks for the help - will try what you have suggested
raptor95GTS
Re: Not disable TVSV
there was loads of debate on this topic on the old forum and the general knowledge was that on rev1/2 with the VSV being a simple on off switch is could left connected however most people disconnect it anyway
The rev3+ VSV is a constantly varying controller and thus needs to be disconnected.
Generally if you are having problems then the darned things get disconnected anyway so most folk don't even have this issue
