Offsets
Offsets
What other cars have the same offset and PCD as the MR2?
Mark Edwards
Re: Offsets
Post by Mark Edwards »
Various toyotas have the same PCD, as do a lot of jap cars but don't know about offset. Honda legend wheels are a direct fit i believe, but don't quote me on it.
Re: Offsets
Cheers for the reply mate.
The reason being that my Blitz wheels have a strange offset combo. This is a cut and paste from the ebay add:
JDM BLITZ 2 Piece 17" Wheels to Suit FC3s / FD3s RX7 、JZA70,JZA80 Supra、, S14,S15 SILVIA/180SX,R32/R33 SKYLINE from JAPAN
Set of 4 BLITZ 2 Piece Classic Wheels to Fit the following FC3s / FD3s RX7 、JZA70 JZA80 Supra、 , S14 S15 SILVIA/180SX,R32/R33 SKYLINE
Z32 300ZX Etc Etc
SIZE:
Front 17"x7.0"+45
5H 114.3
Rear 17"x8.0"+51 5H114.3
So I wanted to know if there were any cars with the same Offset.
Mark Edwards
Re: Offsets
+51 offset!!!! Jesus! I saw a s14 the other day that must of had 20mm spacers on the back of it. That must be why!
Re: Offsets
Mark Edwards wrote:+51 offset!!!! Jesus! I saw a s14 the other day that must of had 20mm spacers on the back of it. That must be why!
I'm not sure that is right tho (ET51) Andy Jones says it's a bit of a weird offset :|
Mark Edwards
Re: Offsets
Don't see why, vauxhalls are +49 most of them. Mine are +35 front and +37.5 rear, work that one out!?
Re: Offsets
hmmm, me thinks spacers and extended hubs #-o
Mark Edwards
Re: Offsets
Depending on how far you want to push them out, halfords do 6mm spacers, that would bring them in line with the +45's on the front then. I have these on my rears and you don't need longer studs to fit either. :D
Re: Offsets
Mark Edwards wrote:Depending on how far you want to push them out, halfords do 6mm spacers, that would bring them in line with the +45's on the front then. I have these on my rears and you don't need longer studs to fit either. :D
hmm, Andy said 5mm was the limit.
that will bring them to ET46 [-o<
Mark Edwards
Re: Offsets
Up to you, i have them with no problems at all, plenty of turns on the nuts to hold the wheels on. If you weren't so far away i'd let you try mine. #-o
Re: Offsets
cool, cheers for the help anyway dude!!
I'll see how they fit when I get them and see what needs doing!
Craig
Mark Edwards
Re: Offsets
No problem my friend. 8)
richGTS
Re: Offsets
Post by richGTS »
check out www.rochfordtyres.co.uk they have a list of all cars pcd, offset and bore. sorry not sure how to make proper link![/url]
Re: Offsets
cheers mate! :wink:
