[Mk2] [Turbo] Rev3 Rear Light Conversion
terminater2_uk
Post by terminater2_uk »
Absolutely gutted. Spent all day changing bulb holders and re-wiring to get my rev3 lights in. Finally got everything working, fitted the lights and then came to fitting the centre panel. Hammered in the back end for the reverse lights no problem. Offered up the centre panel and thought hmmm how does this fit then?
Came in to read the how to guide and realise I dont have the two brackets that hold the panel on. Had to swap everything back over to when I started. Gutted.
Anybody got any rev3 brackets for sale? :(
Greddy-Matt
Re: [Mk2] [Turbo] Rev3 Rear Light Conversion
Post by Greddy-Matt »
Hi
Do you mean the 2 small metal bars per light, each with a screw in each end? If so why not use the ones from your rev 1/2 lights???
-:[KM]:-
Post by -:[KM]:- »
Sounds like the 2 plastic 'brackets' at each end of the centre panel.....
terminater2_uk
Yep they're the ones :(
MaXsteri
Post by MaXsteri »
Which numbers are they on that diagram? I will have to order some this week
-:[KM]:-
Post by -:[KM]:- »
76826-17010 RETAINER, BACK DOOR GARNISH, NO.1
76827-17010 RETAINER, BACK DOOR GARNISH, NO.2
:wink:
Put this into your favourites... it's priceless.
http://www.ayrpark.plus.com/epc1/mr2epc.html
MaXsteri
Post by MaXsteri »
Thanks :thumleft:
