[Mk2] [NA] Plastic Under Body
dmhoward82
Post by dmhoward82 »
Hey guys,
Where I live its belting it down and well cut long story short:
I went through very LARGE puddle :P and it tryed to pull off the plastic under body that bolts on near the exhaust, not a huge piece to contend with looks like its curved to allow air into the engine bay how ever.... I have the piece does this need to be on the car i.e should I get it put back on or doesnt it matter??
dmhoward82
Re: [Mk2] [NA] Plastic Under Body
:-k
Anyone??
shane1978
Post by shane1978 »
helps stop water getting towards engine parts (coil etc) obviously if coil gets wet you may have a problem running your car until it drys out.
Depends how many puddles you go through!
JeffD
Post by JeffD »
Would definitely put the undertrays back on - stops all the road salt etc coming into contact with the underbody - prevents corrosion.
dmhoward82
Yeah the main big one is ok its just the lil curved one but yeah ill get it back on or ill try get it up on the ramps see what condition its in i could replace them whole lot
