[Mk2] [NA] Central Locking Probs
Rev5GT
Post by Rev5GT »
Hi all,
My REV5 UK has a standard fob that locks/unlocks the doors - however it is now only locking the passenger side door and not the drivers... So i use the fob to activate thte alalrm and lock the passenger side and then lock the drivers side with the key.....
Any ideas - is it an easy DIY or does something need replacing...?
foxy-stoat
Re: [Mk2] [NA] Central Locking Probs
Post by foxy-stoat »
had kinda the same prob on my rev2, the key wasnt locking the passenger door, but the passenger door would lock the drivers door and set the alarm, turned out the be the plug that goes from the drivers door lock wasnt connected to the loom, if that makes sence !
you should whip off your door card to see if theres anything-a-miss there. the plug may of come disconnected for some reason or the bar may be stuck.
We ALL make mistakes !!! :)
Rev5GT
Post by Rev5GT »
Will do when its not so cold...
bigvin666
Post by bigvin666 »
check it aint just a sticky lock spray some wd40 in it that sorted mine wen it wasnt behavin
stuyw
Post by stuyw »
ive got this problem too, but i decided to replace the motor in the drivers door as all was ok connection wise when the door card was taken off. I paid £20 for a replacement motor
HTH
Return to “Electrical”
