Can anyone suggest how i can run a speed signal cable (for Sat Nav) from my ECU in the boot to inside the cabin.
I have looked and there are large gromets through from the boot, but i cant see where they enter the cabin!
any thoughts?
The grommit is behind the passenger seat & behind the fire wall carpet, its quite high up, so you need to grab the very bottom of the carpet & pull it up quite high to see twhere the wires enter the cabin, hope this helps, cheers, Jinxy
