Right, need some final questions answering as in the fianl stages of engine rebuld quotes and need to suss a few final issues.
1) wheres the best/cheapest place to get reputable pistons from.
Need 86.5mm forged items.
Have been offered Wisecos at
£400, though I see GTSChris selling a JE set
, same size, for
£349.
Does it get any better than this.
With so many build happened recently/happening now seems a good time to ask.
2) headgaskets.
The company currently talking to is putting forward a Cometic 1.2mm item.
They have trouble sourcing thicker.
Question is, do i
'want' thicker as this will obviously alter the capacity and introduce fuelling issues as the engine will have no standalone for a while.
Will the engine run lean OR will the rev1 setup realise whats happened and fuel apprpriately? While
on the subject, again, whats the best/cheapest source for a reputable h/gasket?
3) fianl one, honest! Whats the going rate for a refurbed LSD gbox? have a quote into the
£500s to rebuild my rev1 box using later internals BUT i have no lsd.
Best route to go?
a)go with this
b)buy a bu88ered lsd box and get that rebuilt
c) get an lsd fitted to this box
d) buya used lsd box from a trusted source
e) buy a refurbed box from a trusted source.
If any of you have ideas and sources for your suggestions this would be greatly appreciated.
Thanks in advance.
Bobby
