When I set it up with them we agreed to use your old IMOC member number, this appeared on the old website but sadly got lost with everything else.
I'd suggest doing the same thing but with your new member number: http://www.imoc.co.uk/forums/memberlist.php
Fensport have web access so can cross reference you to the above if they need to.
ian p wrote:Cheers Michael! one problem though there is no member number on there
You are member no 247.
EDIT: To see you member number just move your mouse over the link to your profile in a post and you will see
Mine is below.. http://www.imoc.co.uk/forums/privmsg.ph ... ost&u=[b]2[/b]
So I am member number 2. There is no member number 1..
When I faxed through an order to fennies about 4-5 weeks ago I wrote on it in big letters LESS IMOC 10% .... since I've bought from them before and was on their records I assumed it would work. Sadly not They charged me full wak!
Small turbos - they're not big and they're not clever!
Just say NO to small turbos!
