Window closure
zero
Window closure
Post by zero »
After fitting remote central locking to my Mk2 I thought i would have a go a fitting a window closure module.
From using the search feature of this forum i thought i had it sussed.
But no.. when i connect the two outputs onto the red wire coming out of the motor on the O/S door the window moves up by about 2mm then at the end of the cycle another 2mm.
By connecting to the green wire going to the motor to the module,when triggered the window rolls down no problem.
So has anyone fitted one of these modules or know what wires i need to connect into.
Many thanks.
Zero
Return to “ICE and Security”
