just a quick query
i've been spraying the side trims in plasti-kote enamel black, and it looks like new.
much appreciated
david
DavidJ wrote:hi,
just a quick query- i want to remove the long plastic strip above the rear window, but don't know the size of deep socket i need.
i think it might be 10mm, but can anyone confirm this for me before i buy?
i've been spraying the side trims in plasti-kote enamel black, and it looks like new.![]()
much appreciated
david
System-G wrote:Hi David,
If you're planing on self-maintaining or doing odd little things to your car, it would be worth buying a full socket set.Also do go too cheap as they break.
Halfords Professional are pretty good and come with a lifetime warranty
DavidJ wrote:err, think i do but don't think it's as small as 10mm.![]()
will check though.
thanks
Lunarmatic wrote:
If your spark plug socket/wrench fits the plugs on the mk1 then it will be 10mm IIRC.
dasher wrote:Hi,
I may be wrong, because it was over a year ago when i took that piece off, but i'm fairly sure they're 8mm nuts.
Regards, Daz
DavidJ wrote:while i'm here, i'm having problems with my battery draining.![]()
i know
(and i mean know) it's not the battery.
does anyone know if the clock is supposed to stay lit when the ignition is off
- it doesn't in my mazda, and i'm guessing the clocks are pretty generic in late 80's jap cars?
either way, i have a problem.
cheers
david
