Cost for one is
$158
$35 P&P form the US.
Suppliers have advise a
Group Discount will be availabe
- so this works out about
£100
or there abouts.
Not sure in import Duty
/ Vat
- we'll see how it goes
If you are definately in for this kind of money please add your name to the below list
- i only want this Group Buy to run for a couple of weeks
- so get in quick
100% in for having one please:
1.
Frank
(Cosmosbluemr2)
2.
Mike
(MikeJC)
3.
4.
5.
Often overlooked, especially on vehicles that are reaching higher levels of modification, is the importance of reinforcing the chassis.
All vehicles experience flexing of the unibody under various handling loads.
Twisting of the chassis is also very common on higher horsepower vehicles.
The SUSTEC UNDERBRACE prevents this unwanted behaviour by connecting specific points of the undercarriage to reinforce the chassis.
Unique internal double-i-beam construction is highly rigid, and lightweight, so the chassis may be significantly reinforced without adding surplus weight.
Noticeable gains in balance and stability are gained after it's simple bolt on installation.
Ultra Lightweight Ovalshaft
Constructed of reinforced aluminum, the Underbrace features a highly rigid ovalshaft design that features excellent construction quality and fitment.
4 Point Bracing
Specially engineered to connect to points on the chassis that would provide the highest rigidity and flex reduction, the braces are 4 point configurations.
By reducing flexing and distortion of the chassis, stability between left and right sides is improved, which means sure-footed handling.
Lightweight, highly rigid double I-Beam
The internal construction of the brace features a double I-beam construction which helps these braces acheive their high rigidity.
The underbrace significantly increases rigidity, without adding surplus weight.
