ANy help welcome!!
Thanks in advance!
MisterTwo wrote:How do you identify a supercharged Mk1??
ANy help welcome!!
Thanks in advance!
ANy help welcome!!
Thanks in advance!
MisterTwo wrote:adam..
.shut it.
Im interested cos i know bu88er all about them and have never seen one before in my life.
A mate asked me about them which left me with a totally gormless expression!
I gathered they had a different engine from the 4 age, just didnt know what and how it looked!
Thanks Lauren for the info..
.your a star!
.shut it.
.your a star!
MisterTwo wrote:Thanks Adam and Lauren, great help.Cheers!!
Apologies Adam, thanks for the pics..
.that looks sweet as!
adamh wrote:other differences..
compression ratio, obvs the additon of other internal components.
the sc has a bigger stronger bottom end than n/a.
does it come with any strut brace
or is that just the t-bars.
i can tell you how they drive im afraid i havent been that lucky to date, where does the power cut in?
Lauren wrote:adamh wrote:other differences..
Yep of course internals are different.Bottom end is same as NA apart from the pistons.
Only the late spec GZE's ie AE92, AE101 have stronger bottom ends.
no strut brace unless its a t-bar.
Also the gearbox is different as are the driveshafts.The Rev1 turbo allegedly shares the same internals as an SC box.
The SC box is much, much bigger than the NA one and quite a bit heavier.
I've driven every guise of SC, standard, modded, manual, auto, levin spec, HKS pulleys, fensport pulleys etc..
over the last 4 years.
The SC is on an electromagnetic clutch, so it clicks on once the vacuum drops below 8mm/hg.
