New brakes pads
blue2
New brakes pads
Post by blue2 »
Does anyone no around how much it costs for new brake pads all round?. My garage is a bit reluctant to tell me and my local motorshop dont supply them. Also the coolant in my car is green, is it ok to add the premixed red coolant from halfords?
My car is a K reg 2ltr n/a
Cheers!!
Dan
JohnnyC
Re: New brakes pads
Post by JohnnyC »
Pads will cost you around £30 all round from Brakes Int (nothing fancy though).
I wouldn't mix coolants, I'd flush the whole lot and replace with red.
User avatar
Lauren
Re: New brakes pads
Post by Lauren »
Any glycol based coolant will do just fine in all honesty. It is a myth that you have to use toyota longlife.
blue2
Re: New brakes pads
Post by blue2 »
cheers for the reply's. Thought the brake pads would be more expensive
JohnnyC
Re: New brakes pads
Post by JohnnyC »
blue2 wrote:cheers for the reply's. Thought the brake pads would be more expensive
They are if you get them from Mr T :D
SUBO2356
Re: New brakes pads
Post by SUBO2356 »
Hi just replaced my coolant (rev 2 Tubby). got the super from halfords, its on offer at the mo by 2 get 1 free. mixed it @60/40, coolant /water, as it says on the tub soI still have a full coolant left, cost £30
AJS
blue2
Re: New brakes pads
Post by blue2 »
I got my coolant from halfords on buy 1 get 1 free but its the premixed stuff. Glad ill be able to add it on top instead of draining hole system. Checked with my garage to and they say its fine.
Dan
