rebuit Rev 2 Block with new bearings, gaskets etc
Ross 86mm forged pistons
toga high flow oil pump
ported and polished head with rev 3 inlet cam
Gutted Tvis plate.
Walbro high flow fuel pump
Aeromotive FPR
Wolfkatz fuel rail
Sard 800cc injectors
Radtec Chargecooler
Apexi Power filter
ATS TD06 Kit, screamer pipe re-routed back into exhaust
Greddy BOV
Pheonix Departure II regular.
Link XLEM, Launch control and flat shift enabled
Rebuilt Rev 2 gearbox, TRD Plate L.S.D
Spec stage 3 clutch
Braided Clutch lines
Poly transmission mounts
Shot shift kit with xxxx spacer block
Koni Adjustables
Eibach Springs
Full High and Tight Poly bush set
Adjustable camber bolts
TRD top mounts
Goodridge braided lines
New discs all round
Pagid fast road pads all round
Dot 5.1 fluid
Staggered ASA FR5 17" alloys
Toyo proxes t1r 245/35/17 rear 215/40/17 front
Speedhut dials
Speedhut oil pressure, voltmeter and boost gauges
Apexi RSM
Sparco Steering Wheel
Momo gearknob
Sony 10 disc changer
Alpine type R Sub enclosure
pioneer 6 x 9's
2 x 400w amps
i think that just about covers it
oh
346bhp
0-60 4.8 seconds
1/4 mile 12.8 seconds
10mpg
