Leeroy wrote:there was a post on here before..
maybe your sensor is out??
You should have 40-50 litres left in the tank when the light comes on.![]()
But why test it!!
It better for the fuel system to keep it above 1/4 tank always
But why test it!!
Lauren wrote:Actually it doesn't matter if you run it down into the red so as to speak.I've just about always done this and never had any problems.
There is 5-9litres in the tank when the light is on, so you can be guaranteed of 35miles with the light on.
I've managed 60 motorway miles
@ 55mph before, no problem.
The guage is very conservative.
Goto10 wrote:Lauren wrote:Actually it doesn't matter if you run it down into the red so as to speak.I've just about always done this and never had any problems.
I heard it upsets the handling a little bit(normally exacerbated by removing spare wheels)
@ 55mph before
With an abrupt stop.
Lauren wrote:Goto10 wrote:Lauren wrote:Actually it doesn't matter if you run it down into the red so as to speak.I've just about always done this and never had any problems.
@ 55mph before
Consider yourself slapped!
Lauren wrote:Goto10 aka Steve, Has had this standing joke that has been going on for far too long.so long in fact that all the possible humour from it has totally gone and i'm getting bored with it after 2 and a half years.
Hence my comment.
L0rdMike wrote:My MK1 petrol light doesnt seem to becomming on.The guage is on the empty zone and my light has yet to come on.
If I keep driving will it come on when im near out or it is broken
.the only thing I can promise for sure is slow progress.
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.![]()
L0rdMike wrote:Dont want to downgrade my MK1 to MK2 standards.Just Kidding.
Leeroy wrote:Lauren wrote:Actually it doesn't matter if you run it down into the red so as to speak.I've just about always done this and never had any problems.
Lauren, Lauren, Lauren![]()
Surely Miss knowledgable knows that if you run the fuel line low you run the risk of pushing all the cr@p that's sitting in the bottom of the tank through your injectors and everything else.![]()
This surely cannot be good for the system, particularly if you do it all the time, and if your tank is 18 years old!!!
I'd be interested to know if you disagree with this??
P.S.It occured to me I didn't mean 40-50 litres, nor did I mean 4-5 litres, I meant 40-50 miles
- as Lauren confirmed
Hence my comment.
Baker wrote:I fully agree with Lauren on this one.why would having less fuel in ur system suddenly push sludge into the injectors? the fuel line into the tank stays in the same place regardless of the amount of fuel.
Crap theory probably, but in any case i dont think it makes any difference.
Also, the benefit of low fuel means less weight..
.faster car!!
50litres= 50kg
(weight of a small passenger)
