heres the way i see it,all 3 wire sensors have the following.
1x earth
1x power feed
(usually 5v)
1x signal wire to ecu
im presuming thats what your new TPS has,the problem is that the 4 wire mk2 turbo TPS has an extra wire for the idle switch setting.This wire which is pink and runs to the ecu informs the ecu when your engine is idling and when you come off idle.
.there will be no problem wiring up the 3 wire TPS to work but it wont have the idle circuit.
Your current 4 wires are as follows.
1x pink idle wire to pin c12
1x white signal wire to c11
1x brown wire to turbo pressure sensor and map
1x red/blue wire also to turbo sensor and map
Ive no idea how you would incorporate your new 3 wire sensor into the map and turbo sensor.
.if i were you id definately find a way to use the turbo TPS on your new throttle body,that is by far the easiest solution.
