yep sidestrips getting done and the tbar edges which commonly loose a bit of there paint.
rear, not sure, may just leave it at the back, i like the look of the stock rear with the nur spec.
the lower rear spats thingys are getting painted, so i can easily replace if i wanted to, all depends on the look i get once its painted.
steve, dont think you need a kit really, i purely did mine as i was colour coding and i thought sod it.
ct20b, who knows if it will, getting a fuel pressure check at the same time.
since cleaning out my afm
(mr2lovers was great, and i realised his was cleaner than mine on the inside and the flap moved more easily, so i cleaned mine and its been better).
