How do i get a-pillar off???
jimGTS
Post by jimGTS »
i have a t-bar, so might make a difference peeps.
i want to install pillar pod, and want to do it well, especially as the pod is a universal one, so will need a bit of work to make it look right.
MarkP.
Re: How do i get a-pillar off???
Post by MarkP. »
The panel basically clips on,you need to remove your T-bar panel then just unclip it from top to bottom.Be careful though the bottom portion that runs down to the sill has a tendency to snap in two.
jimGTS
Post by jimGTS »
MarkP. wrote:The panel basically clips on,you need to remove your T-bar panel then just unclip it from top to bottom.Be careful though the bottom portion that runs down to the sill has a tendency to snap in two.
how do you unclip the part that is against the dash and bottom of the widescreen, seemed like it wouldnt come off???
MarkP.
Post by MarkP. »
Sort of unclip the top part then try pulling the panel up away from the dash.This is sort of when it puts strain on the bottom portion.
jimGTS
Post by jimGTS »
MarkP. wrote:Sort of unclip the top part then try pulling the panel up away from the dash.This is sort of when it puts strain on the bottom portion.
oh right, i didnt really try to much, as i wasnt 100% sure that it was just clipped on!
cheers mate!
Cliff
A Pillar
Post by Cliff »
Make sure to post some pics when it's done mate.
Also.. Where did you get it from?
jimGTS
Re: A Pillar
Post by jimGTS »
IICause_OneII wrote:Make sure to post some pics when it's done mate.
http://www.needforspeed.co.uk/pages/sbv ... Type=PMS01
cheapest place i could find the pod for.
RGM make, universal.
quality of it isnt particulary great, but once i cut it to bits, and shape it around the pillar, should look really nice.
