where is the oil drain bolt on jap 92 mr2 turbo???
ballmysta23
Post by ballmysta23 »
hi,
i wanna do my first service today. i got the mobil 1 and the trd filter and some sparkly new ngk iridium plugs, but cos this is my first time (i dont like being a virgin!!! :oops:) i dont know where the bolt is to drain the oil!!!!!! :evil:
can some one help please :oops:
dj_davo
Re: where is the oil drain bolt on jap 92 mr2 turbo???
Post by dj_davo »
easy fella, smack bang on the bottom of the sump towards the middle of the car.
may be worthwhile buying a new washer from toyota too, only cost 1 quid os so - but dont worry if u dont want to, ive done 2 oil changes without changing it, and 1 where i did change it.
so lying on the floor at the back of the car slide under a bit (you dont need to jack) there is the sump, in the middleish and the bolt is towards the back of it, i think its a 13 spanner one.
the oil filter is near the turbo (next to dipstick towards bulkhead) and it reasonably easy to get off.
hth :wink:
Rory
Post by Rory »
hth :wink:
LOL! Its only easy if it hasnt been overtightened! I think the Incredable Hulk fitted the oil filter on my car before I got it. Took me ages (even using the correct tool) to get it off. Evertime I service my car now they come off fairly easy! Good luck!
Rory
ballmysta23
well thanks mate, i have just finnished my oil change and spark plug change, but i have the same problem as rory!! bloody filter is well tight!!!
and my enguine was is still warm so keep burning my hand :twisted:
but i think once it cools down i'll be able to get it off.
cheers for your help
dj_davo
Post by dj_davo »
little secret for you - an oil filter remover (that has a 1/4 inch opening on for attachment to a ratchet) for a honda fireblade fits perfectly!
i dont think they are expensive (especially mine - i borrow the neighbours) :D
p.s mobil 1 is the best matey - good choice :wink:
JohnnyC
Post by JohnnyC »
Best oil filter remover is a pair of latex/rubber gloves :wink:
Changed my oil recently (inbetween dealer services), and had difficulty even with the sump plug, thought the whole sump was going to come off :shock: (not that a certain Wakefield dealership will be getting visited again in future anyway due to cambelt issues :evil: )
Leon.
Post by Leon. »
ballmysta23 wrote:well thanks mate, i have just finnished my oil change and spark plug change, but i have the same problem as rory!! bloody filter is well tight!!!
hmmmmm..... hope you haven't refilled the oil system if you're intending to take the filter off?? I'm sure you haven't but if you have, and you take the filter off, you gona lose a lot of oil!!! (Unless the filter for tubby is in a different place to NA?)
JohnnyC
Post by JohnnyC »
NA has oil filter in same place as a tubby, but ballmysta23 has a rev1 or 2 that has the filter halfway up the block.
Leon.
Post by Leon. »
:oops:
Tickover
Post by Tickover »
Tip for replacing the filter.. Smear a little general purpose greese or oil around the rubber seal, it will make it easier to take off in the future.. I do this with every oil filter change I do and never have a problem removing even after 18000 miles on one car (wasnt me MR2 was a £100 Astra LOL)
ballmysta23
cheers for all your help,
once my enguine cooled down, and with a lot of gritted teeth and a bit shouting, i managed to get it off!! :P
just gotta get a new knock sensor now??
my motor is driving like a robin reliant with a speed restrictor :(
CUERVO
Post by CUERVO »
:lol: If ur filter is hard to un do " Just stuck a big screwdriver and twist it" It will Fu*K up the filter but hey you are gonna replacing with a new one are you not!!!!
dj_davo
Post by dj_davo »
dj_davo wrote:little secret for you - an oil filter remover (that has a 1/4 inch opening on for attachment to a ratchet) for a honda fireblade fits perfectly!
just to add to this, sorry i got it wrong. the filter remover is for a yamaha r6 - not a honda fireblade. my neighbour just informed me!
sorry if you already rushed out to buy one :roll:
Leon.
Post by Leon. »
I just bought a chain wrench with socket on so I can fit my torque wrench to it - cost £5! Should work fine although I haven't used it yet, I just tightened mine by hand - I must check it though!!
