downpipe gaskets, studs and bolts.
msherry21
Post by msherry21 »
Hi all, another quick question hopefully, Does anyone happen to know the part numbers for the gaskets I require when fitting an aftermarket downpipe? What size studs/bolts do I need? how many? and do they have part numbers? :oops:
thanks yet again.
cantfindausername
Re: downpipe gaskets, studs and bolts.
Post by cantfindausername »
Take your chassis number etc to toyota and they should be able to look it up. I'd buy 4 or 5 to be on the safe side.
***RIP Car13 ***
*** Now in an Evo ***
gtschris.com
Post by gtschris.com »
msherry21 wrote:Hi all, another quick question hopefully, Does anyone happen to know the part numbers for the gaskets I require when fitting an aftermarket downpipe? What size studs/bolts do I need? how many? and do they have part numbers? :oops:
thanks yet again.
if ypur aftermarket downpipe didnt cvome with a support bracket you will need one and i got them in stock if you want one :)
www.gtschris.com
tel: 01670 737080
mob: 07786070103
msherry21
Post by msherry21 »
Chris, yeah. I do need a support bracket, Is that the same as a Gasket? How much? can I buy online on your web page?
thanks.
