Rev 1 and Rev 3 Suspension
mrrwaction1
Post by mrrwaction1 »
Hi just wondered are the rebuildable struts off a rev one interchangable with the struts fitted to a rev three is it just a case of swapping the complete strut over or is it not possible to swap the units over thanks for any advice you may have cheers : Mike
roojai
Re: Rev 1 and Rev 3 Suspension
Post by roojai »
they should swap over no problem. The brake line attachment is normally welded with rust so good luck
