The Car
& Motivations
My car is a Red
'91 UK MR2 with the 3S-FE engine in it.
The engine the twin cam 16valve engine, also found in carinas rav4's and the avensis.
It puts out around 120bhp as standard.
I've always felt the performance of the car was slightly lacking.
There is little or no tuning equipment avaliable for this engine off the shelf, so I fancied doing something a little different than a turbo conversion, hopefully a little cheaper, and mainly to see if it could be done.
This project was concieved just under a year ago, and has been plodding on slowly since.
Various issues have arisen over the course of the project that have been dealt with.
Hopefully all the bugs in the design are ironed out now, and i've thought of most of the problems that need to be overcome to achieve this project.
Piccy Of the Car
Piccy Of my rather spacious engine bay
The Plan
The original plan was to fit an Eaton m45 supercharger
(from a mini cooper S) above the manifold on the right hand side of the engine, running off the aircon pully.
Supercharger in proposed position
The original idea was to run it non intercooled with 5 psi of boost
(max), for ease of simplicity, however this has since changed slightly, I will be using an intercooler mounted in the mk1 supercharger position to decrease charge tempratures, hopefully to decrease the chances of detonation and increase the power gains from fitting the supercharger.
Proposed position of intercooler
As the 3S-FE engine runs an air flow meter as standard, the ecu should be able to deal with the management of the engine with the supercharger
(at low boost) without too many problems.
An SAFC-2 will be used to tweek the fueling and monitor the engine.
Work Done To Date
> Purchased the supercharger
> Test fitted the supercharger, measured
/ designed bracketry
> Test fitted the intercooler
> Purchased pipework, recirculating dump valve
(to prevent the pipework blowing off when the throttle is closed!
> Purchased a tensioner pully
> Fitted SAFC-2
(wiring diagrams avaliable if required as 3S-FE has a different ecu plug layout to the rest of the mk2's)
> Decatted
> Fitted glove box gauge install
- wideband air fuel ratio
& boost gauge
> Fitted knock sensor
> Removed airbox
& fitted cone filter to allow the afm to be relocated.
Work Still To Complete
All the parts required for the project are here now, I'm currently awaiting the fabrication of the inlets and outlets for the supercharger, and the bracketry.
Plans for the future include a custom exhaust manifold project.
Eventually I want to swap the engine for a v6.
The work on the supercharger project is aiming to be completed by JAE this year
[-o<
