HELP!!! engine died, error codes 24 and 31 URGENT!!!
hicks
Post by hicks »
i need your guys help urgently.
took my car on a quick run while the weather was nice and before the engine had even had chance to warm up all power kept dissapearing then coming back on again. eventually the engine cut out and wouldnt start again.
reset the ecu and its now on safe mode and managed to limp home but is reading error codes 24 and 31.
really need to sort this asap as my car is due to be put on the rolling road on the 8th and i have orginised a drive out to the cat and fiddle on the 9th so desperetly need to get the car back up and running.
any help would be muchly appreciated [-o<
thanks in advance
alex.
hicks
Re: HELP!!! engine died, error codes 24 and 31 URGENT!!!
Post by hicks »
found out what the error codes stand for.
31 = Inhalation pipe pressure meter
24 = Inhalation temperature indicator
could this be the air flow meter?
darkmagi
Post by darkmagi »
Hope this helps you it will at least tell you the area to look at
http://www.ayrpark.plus.com/
Let us know how you get on.
Spittinflames
Post by Spittinflames »
I have code 24 showing on mine too :( Posted on here quite a few times asking what it is but nobody could definatly say what it is...... Mine seems to run fine with that error code but would be nice to find out what it is.
Hicks you cant not come the cat and fiddle, You organised it..... You better pinch someone elses car dude #-o
hicks
Post by hicks »
ok........crisis over.
decided it must be related to the air flow meter so before i went and got another one i decided to check around the air flow meter its self to make sure everything was connected etc. low and behold the main connector on top of the air flow meter had come loose :oops:
oh well.
at least the error codes have a use, never would have thought to check otherwise as it wasnt obvious to look at it.
thanks for the replys guys :)
Sidewinder
Post by Sidewinder »
darkmagi wrote:Hope this helps you it will at least tell you the area to look at
Cripes that's a bloody useful website - I had forgotten all about that one!
Nice to see you're sorted now Hicks...all ready for Saturday... \:D/
Mk2 NA Rev1 -*- Mk2 Turbo Rev2 -*- Mk1 NA -*- Mk2 Turbo Rev 3 = all gone!
_______________________________________
"Cruisey, Sporty, more innovation, more adult. A Man In Dandism. Powered mid-ship specialty."
