Which battery terminal clamps?- optima yellow top D34
Shadow
Post by Shadow »
Hi all,
I need to replace the standard battery terminal clamps as they are worn which is a common problem.
Only trouble is I can't seem to find any terminals that fit the small battery posts. I have a optima yellow top - D34 size which is the jap small one, that have the same size posts as the oem battery.
So if anyone has uprated their terminals and still use the standard sized battery terminals posts, oem or D34 could you let me know which one's they've used and where to get them from, it'll be most appreciated! :)
Shadow
Re: Which battery terminal clamps?- optima yellow top D34
Post by Shadow »
bumpty bump, anyone?
Return to “ICE and Security”
