Causes of orange engine warning light??
Matty_GTS
Post by Matty_GTS »
I get the orange engine shaped warning light when i plug in my Apexi Power FC ...
What can cause this??
Matty_GTS
Re: Causes of orange engine warning light??
Post by Matty_GTS »
Oh, its not on all the time, only when i floor it and hit top end of revs or full boost ... somewhere around there where making the most power ...
Quigonjay
Post by Quigonjay »
what psi are you getting when you get the light?
Stuart
Post by Stuart »
Im sure it has something to do with either knock or injector duration. Have a look on your commnander (if you have one) and check to see what your max knock / injector durty lvl's are.
You can set the PFC to flash the engine warning light on when it detects too much knock or if the injectors are maxing out.
Stuart
Chris Wilson
Post by Chris Wilson »
Matty_GTS wrote:I get the orange engine shaped warning light when i plug in my Apexi Power FC ...
You have Boost Control set to ON in the menus, and no Apexi boost controller fitted?
