Hi Mate,
The tube your talking about is the one that oes into the expansion bottle
(white plastic bottle attached to the boot side of the engine bay) this is a storage/expansion tank.
This should have some in it as its where the system pulls more in if its low or pushes out any excess.
I always look under the radiator cap to check mine, then I top it up with some pre-mixed coolant that I bought from MR T.
You dont have to use MR T stuff, I did for pure convinience as its pre mixed and I did a complete coolant change.
You can use some non branded from halfords and the like but I cant remember the exact spec
(I am sure some one will be a long in a mo to confirm what it is though)
I wouldn't use water unless you have no other choice AND you plan to drain it all out and re-fill over the weekend
Regards
PaulM
92 G-Ltd.
