Ticky noise
dawolf
Ticky noise
Post by dawolf »
I'm not sure if this has always been there but I've been noticing a feint but rapid ticking kind of sound from the engine bay, I can hear it in my right ear but not my left so must be on the right side of the engine. Can't seem to work out what it is unless it's wind noise through the vent. I've tried revving the engine stationary and it sounds okay.
Any ideas?
Rob
Re: Ticky noise
Post by Rob »
I have the same with mine mate - Rev2 N/A with 99000 on the clock - but it was doing it at 82000 when i bought it.
I dont think its an unhealthy noise but my ears pick up on anything that i dont think should be there and it bugs the hell outta me.
Maybe tappets???
Goldy
Re: Ticky noise
Post by Goldy »
It sounds like valve noise, mine is a bit 'tapety' at idle but it goes once the engine has warmed up.
dawolf
Re: Ticky noise
Post by dawolf »
Could be, mine is a bit tappety when idling from cold. Need to give it an oil change soon.
Leon.
Re: Ticky noise
Post by Leon. »
I had a similar noise, it was the alternator belt a bit loose (I think causing the pulleys to rattle slightly). Its on the right hand side of the engine bay.
Noises like this are common in the cold, get your belt tightened/renewed and see if its better.
HTH
Rob
Re: Ticky noise
Post by Rob »
Aah thats a good point Leeroy - thats something i havent checked for a while. I must admit - the rate at which the pulleys go round i wouldnt be surprised.
ryan
Re: Ticky noise
Post by ryan »
Ticking...? Does it happen with the engine off? If so, its your watch. Swap from your right hand wrist to your left hand... :tongue:
Wayne
Re: Ticky noise
Post by Wayne »
now then, this may sound way off, but check your manifold studs are tight enough, escaping gas would make a tappity sound which most mistake for worn valves etc.
Worth a look!
Jim_Mr2
Re: Ticky noise
Post by Jim_Mr2 »
does it make the noise when the engine is off, but ignition on?
If so, could be injectors. Mine make a ticking noise.
hicks
Re: Ticky noise
Post by hicks »
mines making a ticking kind of noise aswell. never notice it while im in the car but when i get out and its running on the turbo timer can always here it. not to worryed tbh honest though as car feels in good health.
FreeFall
Re: Ticky noise
Post by FreeFall »
Wayne wrote:now then, this may sound way off, but check your manifold studs are tight enough, escaping gas would make a tappity sound which most mistake for worn valves etc.
Worth a look!
Yup, my old NA did exactly this. Most noticeable when driving alongside a wall or high hedge.
Nick
dawolf
Re: Ticky noise
Post by dawolf »
Yeah that's right, it's most noticeable when driving past walls etc.
Frustrated Pilot
Re: Ticky noise
Post by Frustrated Pilot »
that will be the engine clock then.,..
Leon.
Re: Ticky noise
Post by Leon. »
dawolf wrote:Yeah that's right, it's most noticeable when driving past walls etc.
What exactly is the noise you are getting?
I have a noise that is a high pitch tick/click that increases in occurence as speed increases, it seems to sound with every revolution of the wheels and so seems like a driveshaft issue.......??????
It is also most noticeable when driving past a wall with the tbars off/window down, infact I can't hear it unless in this situation.
:-k
