Should be fine
(considering your running stock shocks) I only say this cause i tried getting the o/e Evo 8 Enkei's on mine
(8x17 et35) wouldn't fit on the front
(fouling the coilover when tightning the wheels nuts)
Stock struts they would have gone on
You can re-use the Mitsu wheel nuts but the centre bore of the Evo is 67.1mm so you'll need spigot rings to take them down to 60.1mm and all is fine
