I was wondering if it is possible to run a MAP sensor instead of an AFM on my engine running standard ecu and an Apexi SAFC2.
Are the outputs from a map sensor comparable to an AFM?
Does anyone have any values for the output of a MAP sensor?
The SAFC has functions to run from MAP or AFM but i'm still not sure if this will work?
Any help appreciated.
Simon
