I did a search and it sounds like several people have integrated aftermarket head units into the premium system using the PC9-406 adapter from Autoleads.
Has anyone ever had any problems with this adapter, specifically with it NOT fitting the stock 14-pin harness? Additionally, does anyone know why it might not work on a US-spec car?
Background:
I started a thread about this adapter over on MR2oc.com.
I ordered one out of curiosity, to see if it was the plug-n-play solution we'd been hoping for.
The plug seemed to be the right configuration, and all the leads seemed to connect to the right places.
After taking a few pictures, I sent it off to another board member who was doing an install.
He reported back that the female 14-pin plug on the autoleads harness was too small to connect to the stock plug.
So now I'm trying to figure out what's going on.
Two possibilities spring to mind:
1) The stock plugs on US spec and UK spec MR2s with the premium system are different.
2) The autoleads part I was sent is deffective; that is, someone grabbed a plug from the wrong bin of parts when they were making the harness.
Neither of these strike me as terribly likely, but who knows.
So, any thoughts? Does anyone have some pictures of the stock 14 pin harness plug on a UK spec car they care to share for comparison?
Here's some more background reading material:
MR2oc.com thread about the PC9-406
Pictures and overview of the adapter I received
I scavenged a female 14 pin plug from my knackered 3-n-1 when I did my install a few years back, so I don't have any personal need for the harness, but the curiosity is killing me.
Thanks,
-Stephen M
