suspension?
will777
suspension?
Post by will777 »
my front right shock has had it so figured it would be a good time to replace all, dont have a grand or so spare for coil overs so wandered if anyone can advise of any places selling good alternatives, i am wanting to lower a bit but not bothered about them been adjustable but also wanting to keep the ride decent as its my everyday driver!
any help appreciated!
luthor1
Re: suspension?
Post by luthor1 »
Lots of this about to search for, but your struts should be rebuidable, so when you strip the old ones down you can slip in a new shock absorber.
KYB do non-adjustable ones, as do bilstein, koni do adjustable ones and are good. Springs to lower it are easy, whole thing should be under £500 or so?
I am a Mk1 bod, so I am sure the others will point you better...
FYI, if doing the job at home USE AXLE STANDS, be careful of anti-roll bar pingig at you when you remove it, and if the nuts/bolts don't come apart relatively easily, get SOMEONE ELSE to do it!!!
:mrgreen:
AndyBrad
Re: suspension?
Post by AndyBrad »
KYB Link
Your also need springs, but theres loads of suppliers for them
Peter Gidden
Re: suspension?
Post by Peter Gidden »
Koni SSK. Adjustable inserts and 20% uprated, 25mm lowered springs.
Around £400 and perfect for everyday ride.
Give Dan a call at DC Dezign.
3sgte
Re: suspension?
Post by 3sgte »
i thought that only rev 1 imports had the rebuildable shock casings
:-k
i had to get some shock casings and had to add another 100 on top of my koni kit still came in under 500 and works a treat
Peter Gidden
Re: suspension?
UK cars too, but easy enough to get hold of.
John Rees
Re: suspension?
Post by John Rees »
Koni adjustable inserts :wink:
RePete
Re: suspension?
Post by RePete »
Given your criteria you could always get new OEM '93+ shocks and springs. The shocks are Bilstein and they're way underrated. That combo will lower the car more than your '92 and stiffen the ride a bit but it'll still be comfy-womfy for a daily.
Mark Edwards
Re: suspension?
Post by Mark Edwards »
luthor1 wrote:KYB do non-adjustable ones
They also do adjustable ones. :mrgreen:
xxxx, AM TUNING, sbITs
