Plastic guard / cover
D_Laverick
Post by D_Laverick »
I need a little help!
My 1994 Turbo recently had a 'disagreement' with a kerb, long story short that after the bodykit that WAS attached to it is resprayed next week, and a bracket or two is straightened underneath, then I'm only missing one part:
The large plastic cover on the underside of the car, that goes from approx the pedals to the start of the engine bay, covering the handbrake cables, and a few other pipes etc...
I would be great if someone knows what it's actually called, and even better if someone knows where I can get one - because I'm at a loss :cry:
BenF
Premium Member
Re: Plastic guard / cover
Post by BenF »
D_Laverick wrote:I need a little help!
Its just known as the 'plastic undertray' AFAIK - there's actually 3 or 4 bits to that if you want the complete parts, and they are different for a Rev1 or 2 car vs the Rev3-on Mk2s.
I'd try a breakers first, MrT won't be that cheap for a part like this...
Kelvyn
Post by Kelvyn »
Speak to Rogue Systems they regularly break up 2's for spares.
http://www.roguesystems.co.uk
Matt@Rogue
Post by Matt@Rogue »
we have the part/s your after in stock, give us a call on 02476 226677 and we can sort you out....
Matt.
